pitbull239
how many speakers can u hook up to a mono amp?
you can hook as many as you want!!
now how about some info?
what sub?
what rms rating?
what coil config?
umm any other info would help out!
having a saz-3500d or a saz-4500d , how many speakers could u hook up to them?
I answered this in your last topic, why start a new one. You can hook up as many speakers that make up a certain ohm load due to there voice coil rating and how you wire them. Go to www.th12volt.com and click on subwoofer wiring diagram to see all the possible wiring solutions. Your over there thinking I have 3500 or 4500 watts lets see how if I can hook up 16 speakers and kill everybodys' system, not a smart way to go about it.
what sub?
what rms rating?
what coil config?
1 saz-4500d and dual 2 ohm 15' l7 kickers and they have an rms of 1000 watts, how many do u think i could run off that amp ?
what sub?
what rms rating?
what coil config?
obviously if you can run 2 for a 2 ohm load then the most you can run is 4 for a 1 ohm load, thats it. You should only be worried about how much space you have in your vehicle to make an enclosure and then determine what you can run from there, not by how much power you have. Just because you have the power to run 4 doesnt mean you have the space.
