CrownVic
Box question
Box for IA 187 15"
I used the RE box calculator and i got this:
width-28"
height-21.5"
bottom depth-18"
top depth-18"
Port height-20"
Port width-3"
port lenght 1-14.25
port lenght 2-9"
total port lenght-28.5"
Port diameter-8.74
square port area-60"
Port volume internal-1710
volume displaced-1726.875
box volume-4.061ft3
frequency-33.76
cut sheet
bottom-28x18
top-28x18
left -17.25x20x17.25x20
right-16.5x20 16.5x20
back-28x20
front-24.25x20
port L1-13.5x20 13.5x20
port L2-9x20
cut angle-90
These dimensions seem wrong to me.
wouldn't the left and right be the same could someone please explain this for me? am i just slow or is this wrong?
thanks alot.
The panels are right. It has to do with the way the panels are oriented to fit with one another. It is kind of hard to explain without a pic, but the left side is the side with the port so the side is connected the the back panel. So 17.25 plus .75 for the back panel width = your 18" depth. The right panel is connected to the front and back panel so 16.5 plus .75 for the front panel and .75 for the back panel = your 18" depth.
Box for IA 187 15"
width-28"
height-21.5"
bottom depth-18"
top depth-18"
Port height-20"
Port width-3"
port lenght 1-14.25
port lenght 2-9"
Port diameter-8.74
box volume-4.061ft3
frequency-33.76
cut sheet
bottom-28x18
top-28x18
back-28x20
front-24.25x20
port L2-9x20
cut angle-90
thanks alot.
The right panel is between the front and back baffle of the enclosure which accounts for that extra 3/4", while the left panel is on the back baffle only since the port starts from the left and works it way over, just look at the picture.
Ok thanks. I wanted to be sure because my dad is building the box for me, but he lives out of town so i'm gonna just give him the cut list and hope he can put it together without a picture.
Any other thoughts or suggestions on this?
I'm getting this box made because the one I have now turned out to be tuned to 53hz I hope that the 34hz tuning will increase my low end output noticably.
It will increase it drastically, just make sure all your other settings are good and you will be fine.
