JusR
SAE 1200-SAZ 1500?
Hey guys, just curious I'm reading on another forum that the sae and saz are comparable! Is this true and are only about 200 watts in diference can anyone elaborate? If so which is better for a single 12 to 15 inch woofer rated about 1-1.5k.
Im pretty sure it is true just by looking at the model number I can tell there is a 200-300 watt difference. They are made in two different build houses with different parts. The SAE is the entry, more affordable line and the SAZ is the beast mode line; both will get the job done. You wont hear or notice the difference between the two (get whichever one is in your budget), both will perform fine on what you listed.
Damn! Kid, you're always on ,and you always have good answers, I just found Jacobs link to clamp tests and it really helped. Thanks.
Glad you came over to the dark side now it just comes down deciding what model is for you. Good luck and no problem man. :santa:
SAZ series is stable below 1 ohm, strappable and can operate up to 18volts.
SAE is a great performer when run at 1 ohm!
SAE FTW! If you're looking to stay within a budget!
Love my SAZ. It's practically indestructible, but then again so are all sundown amps.
Cant go wrong either way!
