I just bought a new mtx ta7801 well I traded 2 R.F. P1's forit but anyway anyone no of any problems with these amps it sounds nice and clean the birth sheet says it puts out 1732w at 1 ohm. Just wanted your guys opinion onit I've never been a big fan of MTX so idk anything about them.
It will power speakers just well, the only way to tell is to hook it up and see. What will you be using with this, thats the million dollar quesiton?
2 12 inch IA leathal injectoins d4's. I have them at 1 ohmin a 3.5^ box with 4 4 inch aeros
Dont worry about the birth sheet at all, thats clipping power. The most that amp is said to put out is 1200w at 1 ohm @ 14.4 volts so unless you can maintain a voltage of 14.4volts then you wont even see those 1200 watts. Just kinda curious why you would ask us a question after you made the purchase (makes no sense)?
Well a friend of mine traded me for two Rockford fosgate p1's they cost like $49 each and I remeber when he bought it new it cost him like $599 and the best part is he never used it. He was just really wanting some subs and already had two of these amp so I traded just because I just didn't know if it was a good amp or not I've never used any if the new mtx products. All of the older ones I have used have blown pretty easy. I guess I'll just be nice to this one lol. It really don't sound bad nice and clean.
MTX are usually good amps so you should have fun with it, as long as you feed it the voltage it needs and set the settings right it will treat you good.
K thanks jay-cee ur alot of help. 
Well I just clamped the amp at 1 ohm and with the gain under 3/4's the way up. It's putting out a amazing 1632 watts I'm just like wow I can't beleve it and that's at 13.56 voltage. There's no clipping or nothing. I think I got a very good deal!!!
How do you know?
