JLp222
distribution block melting
i have a jl slash 1000/1 connected to a yellow top battery but have ran into problems w the distrubution blocks that keep melting only the side that has the wire going into my amp will melt.. i use to have 4 gauge wire than upgraded to 0 and am still having the same probblem would it be the amp? or a grounding probblem?
What sized fuse do you have? How is your grounding (check to see if its in a good spot with sand painted off). I was gonna say to much current going through the wire but you have 1/0 awg on it.
What distribution block are you using?
I'm gonna say grounding, and is there any inline fusing?
Pictutres of said grounding blocks and installation please.
J
Also, if the fuse is loose it will melt. Good idea to check and tighten those screws every now and then or use some blue loc-tight on them. Vibrations will slowly back them out.
