ok so what would you sudgest i get ?
You will have to look into amps that can do roughly 1500 rms @ 2 ohm. The only brand I know off the top of my head that rates @ 2 ohm loads is Kicker but you can look into other brands that have it rated @ 1 ohm loads and just see what they are rated @ 2 ohm. I just think that you are looking for much more of an incease in how loud your subs will be then what the Hifonics will give you.
for the 2,000 watt Brutus hifonics
Type: Mono Block
1-Ohm RMS Power 1x1600
2-Ohm RMS Power 1x1100
most of the 1500 kicker amps ive seen are like 450+ range.
im kinda confused. This amp is rated for 2,000 watts but its not ratted for 2,000 watts even at 1 ohm ?
Hifonics overrates their products but im shocked that it is that low. A lot of companies put the max watts in the amps name so people think it can do more so that could maybe be the thing that hifonics was doing or it could be the rms with 16 volts instead of 14.4 possibly.
What the hell are you talking about, every site that I look up an Hifonics amp is says it does the 2000 x 1 @ 1ohm for the Brutus 2010:
Hifonics Amp
Yeah man stop making this so hard, just find an amp that does what you want it do at 2 ohms and fits into your budget. If your stuck on Hifonics amps then check out the BXI-2010 or 2610, those will fit your needs.
You need to do your Big 3 Wiring if you havent done so and get you a secondary battery for you amp.
ARG sorry... but at this link http://vminnovations.com/product_1272/HIFONICS_BRUTUS_BXi2010D_2000W_Mono_Amplifier.html
they rate the amp at those ratings..
Yes i will do my big 3 upgrade here in the spring I dont see a real reason to do so yet As winter is coming and i wont be bumping when their is ice on my Truck.
Sorry for making it diffacult Im just trying to figure it out so I know exactly what i am doing so i can do it right the 2nd time :) and not Shoot for a 3rd.
call or email the company about the ad. They will let you know for sure. Don't be afraid of this company because of one misprint. I have bought from them many times from cell phones to amps. :D ap1500d. I did however, buy through their ebay store but it would be stupid to have weaker customer service on their main site. With you needing a 2 ohm load, it may be better to look at some kicker or rockford amps on ebay or something because most of them will output max RMS power at 2 ohms instead of 1 ohm, if 2 ohms is what you need. I skipped through some posts :D.
