ok heres the thing im putting in a center console with a tape player in my s-10. i removed the tape player so i can put my bass knob and a toggle switch where it should be. im gonna have plexiglass fill the hole and i wanna put a green led behind it and wire it to the hvac or anywhere in there so it comes on when the lights are on can anyone help me with this on any part. how to put the led back there so it lights the plexiglass and wire it so it comes on with the lights. its a 2002 s-10 xtreme,
maybe just wire it to a relay(or the ignition wire) so it turns on when you turn your truck on? and put the LED on the EDGE of the plexy
take a loook on 12v.com if you need a wiring diagram to wire into the harness.
Edited by CrazyKenKid
i thought you were asking how to illuminatea piece of plexy glass and how to hook up the led. sorry man
hey pos the link you were on.
with the 12volt site i was just saying if you wanted to run your LED through your harness the 12volt site would tell you which color of wire to tap into for power and rem. so you could turn on the LED when you turned on your truck.
The good thing about LEDs is if you wire them backwards they won't blow. Just reverse the wiring and they'll work.
You'll need to either get prewired LEDs (they already have the resistors oldered) or figure out what size resistor you'll need for the LED you'll be using (this can be a pain).
I'd suggest visiting oznium forum. They can help you out a lot better. I've done something like you want in a vehicle. Really wasn't that hard.
