Lucky 76
Question about batteries needed
So I emailed xs and asked about what I needed as far as batteries go. Here is the actual email. I just wanted to know if this is all I really need? I want my voltage to stay up and dont want it dropping.
What would you recommend for my current installation? As it stands
right now I have a 260 amp alternator. I drive a lincoln aviator which
is the same as a ford explorer. The stock alternator was a 130 amp. I
do not know how much current draw it pulled but I am sure it is more
than the average car. I listen to my music loud 90% of the time.
As for my current installation goes I have 4 of the sundown saz1500s
going in which have fuse ratings of 150 amps and then I have a sundown
sax100.4 and a sax120.2 which have fuse ratings of 90 and 60. So that
is a total fuse rating of 750 amps. I am assuming that it would be
better for me to replace my stock front battery as well to prevent
voltage equalization of the different batteries.
Just let me know what you recommend and if you could give me a price
on it shipped to 06795.
Thanks,
Christopher Perugini
Here is the email from them:
Hi Chris,
We actually have a new model that will bolt directly in place of your
factory Group 65 battery. It is our D6500 model and it will be available on
November 20th. If you cannot wait until then, our D2700 model may fit if
you have some additional height clearance. If there is not enough height
available, you can go with our D3400 and it will fit just fine. These
batteries, along with your 260A alt will provide enough power to supply
about 3kW. To properly supplement your 7,500W system you will need to add a
secondary bank in the back. There are many options to choose from, and I
would select whatever best fits your installation. For example, you could
use 5 D680's, 3 D925's, 1 D3100... the selection is up to you. To get a
better feel for the wattage, refer to the attached brochure. Once you know
all the items you need, just let me know and we'll get you a shipped price.
Thanks!
Customer Service Team
Cant go wrong with Xs batteries.
or tons of AH.
If you want your voltage to stay above 14V during continuous full volume play, you will need to have enough alt power to supply the entire system. If you just want to minimize the amount of drop below 13V, then just add an extra battery just for good measure.
Listen to Scottie. :)
Ya ill stick with the recommended. It saves me money. If worse comes to worse I can always buy another.
This is true. :)
with that amount of draw I'd do a d2700 up front and a d3100 if not 2 in the back and you shouldn't have much to worry about
I run 7,800w in the back off 250A alt so i can be a good comparison to your needs.
I run 177aH just in the back of XS power and it isnt enough.
I personally need 3 D2400s or 2 D3100s and a larger starting battery at my preference.
I am going to run a single d3100 and the new starting bat they are coming out with and I will go from there.
Out of curiousity what does your electrical system consist of? 1 - 250A Alt, and what qty of batts? What about it isnt enough? I would be happy to help with recommendations on what could help meet your needs.
Thanks!
