Your amp choice will be determined by your woofer. If you have a dual 4Ohm, you can wire it for 8 or 2 Ohms so that means you need your amp to provide the recommended power at those ohmages. Then it is a choice of quality. You can get a Yugo, a Toyota, a Ferrari.....etc. You mentioned Hifonics so I would probably call that a Ford. So get a Ford that makes 800-1100 watts at 2ohms or whatever brand that provides that kind of power..
please dont limit your self to one company
For HF bx1205d 900@2ohm. Plus you got a 1200 watt amp if you ever want to get a big dual 2 guy. Id personally suggest a Memphis 1000d or 1500d. But thats just me and I love memphis amps.
i second fonzi's suggestion...
also, if it's a d4 (which it is unless u got in the GB), i'd suggest an mtx 801d...sweet lil quality product..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
if you need a 2ohm load check on ebay for an RF 1001bd, very solid amp with excellent power
