seanmartin3
Okay 2 12" Fi SSD D1 ohm subs
Ok so i have 2 12" Fi SSD Dual 1 ohm subs, and i want to have a final ohm load of 2 ohm. Can someone show me how to wire them?
Try using the search function, sometimes you can find things out before asking questions (research is the key to your own knowledge).
Please dont start another topic talking about the same thing.
You could wire a single voice coil on each sub to get a 2 ohm load. That is not a recommended method and it reduces your power handling somewhat. Otherwise you could wire each sub up to a 2 ohm load each. You can't, however, wire both subs and both voice coils up to a 2 ohm final load.
Can't with Dual 1's...
What amp do you have?
