seanmartin3
How to wire
What is the final ohm load you are looking for?
You can wire it parallel or series, series will give you 2 ohms load, parallel 0.5 ohms load.
  On 10/7/2009 at 2:01 PM, SeanMartin said:
Ok i have two 12" Fi SSD Dual 1 ohm subwoofers. How would i wire both of them to only one channel?
Please HElp me
No problem...
What load are you looking for at the amp, is the 1st question you need to ask yourself??? 1 OHM or 4Ohm???
Then go here...
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=12
On the "Subwoofer Wiring Wizard"
There will be two drop down selectors....
Speaker QTY (Pick 2) and Voice Coil Impedance (1 ohm, Dual)... Then click "View Wiring Options"....
it will show you what you need to know...
I used this way back when I had (3) Dual 6 Ohms sub that I needed to run @ 4 ohm... as the amp was only 2 ohm stable in Mono...
Hope that helps...
