SmokeyDog
topic title idk
I have a question about ports. I am having finely decided to use round ports. But I have a problem; I have 8.89ft3 I want to tune around 38 Hz. The problem I run into is I need like 15’’ of port. The box is only 14’’ deep, going with 2 8’’ ports. So, can I bend the port with a 45? So it will make it in to the car with out a problem. If yes, do I have to add any thing to the length, or do I just cut the tube where it needs to be and add the 45 in between the cut peaces. Trunk setup subs up, port up going thought the rear deck.
yes you can use 45's to bend it just measure down the middle to get the correct length.
thank you,, when you say measure down the middle, that being the middle of the tube in the center bend and all?
2 8's does NOT equal a 16, not even close
