lamchop_8
AQ3500D Or Stetsom V 4K2D
I plan on buying a HDC318 dual 2ohm with alum coil & upgraded spider pack and Im giving 4k to the sub The AQ puts out 3500rms @1ohm And the 4k2d puts out 4200rms @2ohms @ 12.8volts @ 5000+wrms @2ohms @ 13.8volts. So what amp would be better and more efficent between a aq3500d and a stetsom 4k2d?
so if you go with the stetsom you are going to get a d1 18inch sub? and i would go with the stetsom myself. but if you need to save money go with the AQ. and actually jacob did some testing with an aq vs a saz3500 check it out
I would go Sundown SAZ-3500D, FTW!
Ok thanks & I will be getting a dual 2ohm sub if I go with stetsom because the lowest independence is 2ohms but one thing I dont like about stetsom is that they dont have a subsonic filter. =(
How much is it?
? with a duel 2ohm sub the only ohm load you can get is 1ohm or 4ohm. so you want to run the stetsom under its rated power.. ;) lol
okay i also heard a rumour about those stetsom amps that they are for spl and burping and aren't the best at daily? i don't know and i can't vouche for that rumour but i thought i would let you know and hopefully someone can chime in and explain or deface that rumour.
How much is it?
they were on pre-sale for like 800 ish. as for now you have to contract a rep and ask.
http://www.db-r.com/sell/store2/index.php?main_page=index&cPath=65_67_69_97
and
http://www.db-r.com/sell/store2/index.php?main_page=product_info&cPath=65_67_68&products_id=227
That AQ won't last long with someone who doesn't know what their doing at the controls and 4krms on tap.
good point! but he can learn! and on here he can learn from some of the best!!! and brightest!
Yeah its a rumor I personally talked to stetsom and they said the amps can be used for daily. And I was going to wire the subs in series wire to sub & wire to the amp no paralel wiring so wont that be a 2ohm load?
Yep! =)
you are mistaken! when we talk about series it is just like adding! so 2 plus 2 = 4!!
when you put a sub in parellel the ohm load will drop by half. so 2ohm plus 2 more ohms in parellel = 1ohm!
now if you get your sub in a duel 1ohm you can wire it to a 0.5ohm load or a 2ohm load!
but if you get 2 subs that are duel 2ohm you cna wire the sub to 2 ohms! by one sub at 1ohm and the other sub at 1ohm also then put the 2 subs in series to get a 2ohm load!
http://www.the12volt.com/caraudio/boxcalcs.asp
and
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=12
How much is it?
Check this out:
http://www.soundsolutionsaudio.com/store/products/Sundown-Audio-SAZ%252d3500D.html
and
Well the nonimal independence on the hdc3 sub is 1.8-1.9ohms So what if I wire it paralell making it 1.3-1.4ohms and then it will go up after independence rise making it close to 2ohms wont it?
well you can't bank on impedance rise and fall. banking on that is a two way street. it will go up and it will go down. and if it is even 1.5ohm perciol that is a 0.75 ohm load.
and 1.8 and 1.8 in parellel is like .9 ohm load
Edited by CrazyKenKid
to better understand impedance rise give this a quick read over
here is a saz3500 from db-r. keep in mind reb and b-stock aren't a bad thing. esspecial if you are going to save money!!
http://www.db-r.com/sell/store2/index.php?main_page=product_info&cPath=65_67_69_97&products_id=230
i have heard nothing but good from db-r and this amps are 100% and fully tested. he isn't a fly by night guy and he is also recommended! so buying from him you can't go wrong!! so don't be afriad to purchased rebur stuff esspecial from him!! and i am sure plenty of ppl can vouche from him!
Okay thanks & like I was saying the stetsom 4k2d amp is not 1ohm stable it puts out max power @ 2ohms (like kicker amps) and only one sub will be hooked up to this amp so you said get a dual 1ohm sub instead of a dual 2ohm sub?
yep! if you plan on using the stetsom get a duel 1 ohm sub and if you get the saz or AQ get a duel 2 ohm sub!!
also if i can ask are you planning on buying the stetsom bnib? (brand new in box?)
Yep. Why?
  On 9/30/2009 at 2:09 AM, CrazyKenKid said:
congrats!!!
Thanks! & what do you think about their amps?
Edited by Randy.D
two dual 1ohm subs .25, 1, 4
two dual 2ohm subs .50, 2, 8
i heard they are quality! but i have never heard one played before in real life!
You think they put out their rated power?
