matt cusack
fi ssd 10 speaker wire size
i have 2 fi ssd 10's and was wondering what speaker size the terminals are? or what could i fit/need in them? and also i have some scrap 8 AWG power wire laying around could i use this as speaker wire??
noob question i know but i figure you guys know better than anyone.
Thanks
Matt Cusack
Thanks
Matt Cusack
8 gauge would fit in the terminals but I think its just overkill to use, I personally run 13awg from my three subs to an 8 gauge connector then just one wire leaving each connector (positive and negative) going to the amp. Its all personal preference but 8,10, 12, 13 is acceptable.
12-10 gauge should be more than enough.
You can use your extra power cable, might have to trim off a little if it doesn't fit.
ok cool. so basically power wire and speaker wire are the same thing?
Thanks,
Matt Cusack
Well, technically, speaker wire has two leads (+ and -) while power wire only has one. But there is no difference in the actual conductor, you're right.
