seanmartin3
Wiring HELP!
Okay so i got the 2 12" Fi SSD and i have a 1800 Watt MA Audio 2 Channel Amp
The subs are dual 1 ohm and i was wondering how would i need to wire them?
This is for EACH sub:
The sub has 2 voice coils (two positive and two negative connections).  Run a piece of wire from the positive of coil 1 to the negative of coil 2.
Then wire the negative on coil 1 from the sub to the amp and the positive on coil 2 from the sub to the amp
Wire one sub to each channel of the amp.  This will give you a 2 ohm per channel load on the amp.
Brian
Brian
x2
