porkchop
making the most out of this amp.
Crunch Powerzone P 900.4
4-Channel Amplification
900W 2 / 3 / 4-Channel A/B Class Amplifier
115W x 4-Ch @ 4-Ohms or
225W x 4-Ch @ 2-Ohms or
450W x 2-Ch @ 4-Ohms Dynamic Music Watts
we have this and (2) IA 187 12"s ..... dual 4ohm.
what do i need to do to wire the two subs in order to get the most out of this amp?
thanks Chop
thanks Chop
It looks like the only option I came up with is each sub on its own channels (two channels wont be used), wire the subs in parallel to 2 ohms.
so you are saying it will be doing 225 then? i think he reall wanted to get more out of it, kinda sucks, he got it dirt cheap.
if i was to bridge one side at 425 watts and use other a two channels for like his mids, what do you think?
Yeah regardless of how you wire your subs to that amp, they will only take up to channels of that amp. The other two channels will be open for anything, good luck.
Id bridge the rear channels and wire the subs to a 4 ohm load instead of running them in 2 ohm stereo
looking toward doing that^^^^, raining today and he will not bring it out in the rain. :coolugh:
That sucks, tell him to stop holding out (weather never stops an install). Just playing
