TEARfromRED
SQ Box Design for 10" Kappa Perfects
looking to make a sealed enclosure for a 10" Infinity Kappa Perfect DVQ. the sub will be getting 400rms, just trying to get some confirmation on the dimensions of the box i should make
based on my reading I should be looking for a box with about .8 cubic feet and using the mid-size insert.
this look correct to everyone?
With no pole piece -- infinite baffle or very larger boxes (sealed)
With low Q pole piece -- very small boxes (sealed/ported)
With Mid Q pole piece -- mid boxes (sealed/ported)
This sub would work the best in an infinite baffle but sealed isn't that bad either. If u use the the low Q pole piece and place in a .3 to .4ft^3 box. If you use the midQ pole piece use a .75ft^3
box. If you choose the no pole the best would be infinite baffle
