flakko
What is going ON??
ever since installing my comps. The sub's performance has taken a drastic turn for the worse. I set the gains correctly (w/ dmm) givin it around 600w, increased the bass volume a lil on the HU.
When everything was all said and done, the subwoofer did not get as loud (my ears dint get used to the sub my rear view mirror did not shake at all like it used to) , and the sub did not play as low as it used to before installing my components.
i played daz dillenger's "my system" and on the reallly low parts, my sub didnt play anything!! I felt no rumbling like i used to. I checked all the crossovers, filters and everything, but they were fine.
I swear... either i fix this or im goin smaller subs with less power. sheesh...
any help about what is going on will be greatly appreciated.
whats your electrical system?
Good one flakko, you busted it
No idea just wanted to scare you
You shure you have the right RCA going to the right amp ?
x2
i dunno why else ur sub's performance would slack off after installing componets.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
ooo RCA's are fine.
found out the speaker wires were reversed i forgot what the term was (lil help!!) but the + and - were mixed up. everyhing works fine now! :D
one way to test that out is that if u mix them, touch the cables, if they get a little hot, then they are reversed.
ooo RCA's are fine.
out of phase...
so when u installed ur componets, u unhooked ur subs? and then hooked them back up out of phase?
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
ooo RCA's are fine.
:idiot:
That's sig worthy stuff right there!!!!
I think chinny was smokin the reefer when he thought that one up
actually it works, try it nubs :finger:
reefer is weak, mango chronic and purple is a diff story
No need for drugs.
specially supa he set me up :'(
