Anth666
IXL-10 with US acoustics USB2150
Hi, just wanted to know if the IXL-10 2.2 would live well with a US acoustics USB2150 wired at 4ohms
Here are the specs for the amp:
2 x 150 @ 4ohms at 12.9 volts
2 x 225 @ 2ohms at 12.9 volts
1 x 450 @ 4ohms bridged at 12.9 volts
THD less than 0.01%
Frequency Response: 10Hz-30kHZ, -0.5 dB
Input Sensitivity: 100 mV - 8.0 Volt
Crossover range
Low Pass: 40 - 460 Hz
High Pass: 65 - 4.5 KHz
S/N Ratio: 103 dB
Channel Separation: 90 dB
Damping Factor at 20 Hz: 95
Reverse Polarity, Thermal, Short Circuit, and DC protection.
It would be installed in the driver's side hole inside the trunk in a stealth-like box.
The reason i'm looking into the IXL-10 is mainly because of the price and great reviews i am reading.
I know the amp isn't giving even half of the rms rating of the sub but maybe could be good in a small box.
If you have any other suggestions of sub that i could use in same price range that would better fit my amp,
please share.
Thank you for your time.
Phil
Edit: another reason is that i live in canada and save a bunch on shipping and duty charges.
Edited by Anth666
I had mine off 450wrms for ages and it was excellent quality the only limiting factor was output. What are your goals for it? pure output or a nice addition to the sound of the system?
Jono
Great sub, nice amp, sounds like a great plan to me. :)
I just want a good addition to my sound system. Here's my setup:
Kenwood KDC-X589
front stage: crossfire neo 6.0
rear fills: mach5audio MLI-65
amp: infinity 7540a
I think that a IXL-10 2.2 would be a great addition at an event better price.
Just not sure is i should run it at one channel per coil or in series bridged
to give me 4 ohms. The amp as the same output either way.
Tell me what you think.
The IXL drivers as a whole are very efficient drivers. I have my IXL 12's running off of 400rms each and they get crazy loud. But they blend in seamlessly if desired.
Edited by Puggsley456
