Kyleebbert
18' Bl Ported Box Recommendations
I have my 18 bl and my car now so im ready to construct my box to fit my trunk. Ill be running the sub and amp at 1000rms at 32mhz. The trunk has alot of space but im worried about putting the box into the trunk so if anyone can give me the proper dimensions for 32hz please let me know and does anone know a good calculator tool for this so i can calculate the port size also? THANKS!
You have to measure your trunk an see how much space you have to work with first
Well I measured out a box already that will fit the trunk its 30' deep/ 23' wide/ 17' tall, but i have about 19' of height, 32' of depth, and 25' wide to work with in the trunk. So basically I need a box around those measurements more or less, the only thing i worried about is getting it inside the trunk when its built. If anyone has any suggestions to what I should go with to max out the performance such as cubic ft and hz please feel free to post your oppinions. Also I think it would be good to tell you guys my expectations. I want it to sound loud and hit hard inside the car, but also very deep on the outside so you can hear me COMING!!!
Edited by KyleEbbert
