DjFreddyFred
2 18" btls and 2 3500d's
Install is thursday morning..and im just checking....I have 2 18" Btls fully loaded Dual 2's and 2 Saz 3500d's, amps are gonna be strapped...this is the best configuration?
Thanks,
Freddy
strapping your amps at 2ohm (so each amp will see 1ohm each) would be the safest way to run any sundown amp! do you plan to run your amps at 2ohm or 0.5ohm?
well if strapping them at 2 ohms is the safest way then i guess that is the way to do it.... how will the subs be wired to the amps?
wire them in series to 4 ohms each and when added together they should drop down to a 2 ohm final load.
