4X4AUTIGER
What would be louder
Would 1 10" bl with cooling and flatwind coil in a 1.4 cuft box tuned to 32hz be louder than 2 10" ssds in a 1.8 cuft Tuned to 33hz? Also what would be the ideal port area for the ssds if I put them in a box with two ports? Thanks
2-10" ssd's in my opinion, you would need anywhere between 21.6in^2 - 28.8in^2(divide that in two if you want to make two ports).
2- 10s more air = more boom
awesome! but could i go any smaller than 1.8cuft? im really pressed for space since these are going under my rear f150 seats
if i were you i would just go with one of those MTX thunder forum or whatever their called they make them for 2 10s unless you want to get into some fab work. Plus the look like something that came with the truck...they look clean and stealthy. as far as space I wouldn't go less than 1.6 MINIMUM
well i already put in my seat lift and have my amp (sundown audio sae1200d) but im still looking for the right sub/ subs. I want either 2 10s with 600w rms handling and 6" mounting depth and require like .7 cuft ported or 1 10 or 12 with 1500w rms and 6.25" mounting depth and 1.4 cuft ported
good with what can fit because crampped subs in a small box will not sound to good or give you the best output. just my .02
alright yeah i think im gonna go with the 10" Bl with cooling and flatwind
Don't forget you have to subtract port volume from the total volume of the box too.
and the sub woofers displacement also
lol and bracing.
lol and bracing.
x2
yeah we were just joking for your situation (but for some people who dont know that those values must be thrown into the equation when building a ported enclsosure).
