bassfreq
Blown BTL
I have had my BTL for less than 1 year and it is now dead. I had it powered by a zx2500.1and it is in a properly sized and tuned box.. NO bass boost, subsonic on, gain 1/2 way up. The spider is ripped a little bit but I can not see any other damage. IT does smell funny. I am a responsible user and did not abuse the sub whatsoever. I have been installing and using car audio for years,. Does Fi have some kind of warranty, Can I send it back for a recone? I would appreciate any input. THanks
Edited by bassfreq
You can buy a recone kit off of their website, as far as warranty not sure.
What sort of charging system do you have for that amp? It sounds like you clipped it to death, did you measure the voice coils?
No offense, but if it smells burned you were not being responsible. Just because you had the gain 1/2 way does not mean anything, there are many other factors.
I don't believe there is a warranty due to the nature of the sub. Sounds like time to recone.
There is no warranty...
The Kicker amps have one major flaw as they do not have a adjustable subsonic filter. I believe it is set at 25Hz @ 12dB per octave which is a very low shallow slope for a SSF. Your enclosure would have to be tuned 30Hz or lower for it to be effective..
What you saw happen was the toll of time of abuse of not having a proper subsonic filter / tuning of the enclosure for the amp. No sub will take that if it is any sort of high excursion woofer or anything that has a long coil that is designed to move more then say 25mm.
You can definitely send it in for a recone and we can get you back running again no problem, but if you are planning on flopping another speaker in that same box with that same amp it simply isn't going to last.
Thanks!
Nick
Yeah, I'm afraid you aren't as responsible as you think. After a year it is no longer a manufacturer defect. You simply had too much power on it.
damn that sucks to hear man and I hope you get everything worked out in the end(I hate being system or bassless). Im glad I didnt buy a kicker or piooneer monoblock amp just for that reason their (no adjustable sub sonic filter).
I know you paid an arm and leg for it but I suggest you sell the amp, get a recone for you BTL and buy a Sundown amp. good luck
dont get me wrong im not putting any fault on the subwoofer. It has been great and extremely loud for a single 15. So you would think it would be ok with a box tuned lower than mycurrent 33?
sell that amp and get one with a variable subsonic filter. just my opinion.
I don't like kicker amps because of this fixed subsonic filter. You don't have much room to play around with box specs.
Thanks!
Nick
Thanks!
Nick
I noticed you have Kicker as your official amps for the product. Maybe you should look at Zapco. It also helps that I am the rep out here for Zapco, and having a BTL, I can attest that it is a MUCH BETTER PRODUCT than Kicker. We built a system in a Honda Element running 2, just 2 Zapco 9.0's to 8 Cerwin Vega vmax 15's and it hit 159-160dB consistent. I have absolute faith in the product, and yours too. Here are the specs:
Stereo, 4 ohms: 2x300
Stereo, 2 ohms: 2x600
Stereo, 1 ohm:2x1100
Bridged, 4 ohms:1x2200
Bridged, 2 ohms:1x2200
T.H.D. + Noise:
Frequency Response: 20Hz - 20KHz, + 0dB / -0.28dB
S/N Ratio: <0.05% @ 4 ohms
Transient Distortion: <0.009%
Slew Rate: >20V/uS
Damping Factor: >225 @ 4 ohms
Input Sensitivity: 250mV - 16 Volts
Dimensions: 19.5"L x 8.75"W x 2.375"H
2-Channel High Efficient Full Range Class D Amplifier with Tripath Microprocessor Control Technology Over 2000 Watt RMS Power into 2 Ohm or 4 Ohm Configuration
-Chassis design allows infinite customization options by replacing slide-in trim panels to personalize any installation
- SymbiLink™ Balanced Line Technology provides up to 16 volts of balanced input for the cleanest, quietest signal possible
-Dual 1,800 watt power supplies for surges well in
excess of rated output power for SPL use
- Three independent output filtering stages allow full
range use as well as bass use in SQ systems
- Optical isolation at each stage
- ZAPCO DCS microprocessor control for all amplifier
functions
- Ultra high speed switching frequency for reduced
"footprint"
-Adjustable input gain up to 30.5 dB
-Adjustable Pre-Clip circuitry enabling the user to set the maximum input which in turn determines the desired output. power. Match RMS speaker power handling for best performance and reliability
-Adjustable turn on delay from 1-4 seconds
-XD-VFD in-dash display, with wired remote, allows monitoring and control of all functions from drivers position display shows, input voltage, amplifier rail voltage, temperature and output power
- Variable, selectable 24dB or 48dB low pass
crossover
-Pass through output
-Four layer PC board with heavy 3 oz copper
-Surface Mount Technology w/1% resistors, precision capacitors, and massive ground planes
-Switch for use as stereo , single L ch. or R ch. bridge
-L+R sum mono for use as a bass amp-
-Dual cooling fans allow any mounting position
-Three year warranty (If Authorized Dealer Installed)
- Quality ZAPCO construction
** Designed and Manufactured in the USA **
Technical Bulletin C2K 9.0 4KW
Zapco makes great stuff..however the vast majority of the people who run the subs simply can not afford a zapco amplifier...because they are pricey.
I just use Kicker amps in the demo vehicle because they work well and I have the processing power to not have to worry about the amplifiers not having a subsonic filter...
-Nick
