Pezzaboi
quick help!
im fitting my FiQ 15 bp and sundown saz 1000 this sec
its 2.3^3 box sealed, was just wondering a rough guide line to set my LPF, Subsonic, phase at?
listen to rap,
thanks
everything is on min, or same as min gain atm?
so leave yes? just set gain
use 50Hz tone, turn gain up slow till satisfied whilst being careful
yes, do u have a dmm to set the gains correctly?
ssf - 0
phase - 0
lpf - halfway
going to hit bed now, am not successful yet :(
amp is working all lights remote everything but sub not making any noise and no movement?
any ideas, all seems wired up ok, +amp to +term - to -
check the head unit settings, and all the connections (amp, battery, head unit and rca's). hopefully its a small trouble shooting problem.
my step dad did check for current running all the way through, amp is powered, and grounded. remote from stereo is working, amp remote lights up, i put it on half for now.
im just trying to see any movement from the sub.
doesn't matter where the gain is im getting nothing?
grrrr this is annoying.
also i feel like i have had the sub to long to do anything even if its broke. its been sat in my room for 7 month whilst i am getting the other peices of my system.
im going to have another look.
please post ideas
thanks
just to check.....
speaker wire...
i have 1 pos to cup to + term on 1 side of sub.
and 1 neg to cup to - term on other side of sub?
sound right ?
That doesn't sound right. The Fi has dual coils. You should have one wire from red terminal on one side of sub to the red terminal on the other side of the sub then to positve speaker on the amp. Then wire from black terminal on one side of the sub to the other black terminal on the other side of the sub then to the negative speaker on the amp. If it's a dual 2 then you have a net 1 ohm load. Can you post pic of how you have it wired now?
Make sure your RCA's are in the back of the HU and Amp
yeh i think i did. its now working :)))
gunna go set it up better now....
set to about 23/35 on my alpine on 50 hz tone increase bass untill reasonable...
is distorion easily noticed on subs being very low sound
thanks
seems to be working fine :) had it going most of yesterday
pretty loud im going to get a dmm on it i think it can take more no where near max xmax
super sub am way happy.
thanks
