BILTD
Ascendant Audio Chevy Astro
OK, so you know how it goes.. Screw heads break off, T-nuts spin and any other method needs you to be mounted inside the enclosure.
We designed these on CAD and had them punched and the PCD measurements pre-drilled.
48x 6mm pieces which are reverse mounted to the baffle.
So they needed too be drilled to accept a M5 high tensile bolt... Thats 96 holes that needed to be drilled on the press, hell I went ahead and did the mounting holes too which made 192 holes.
Took me 6 hrs to hand tap all 96 holes..
Anyways back to the enclosure!
Here are the 12 18s stacked up.. (few other subs there.. yes I stacked them that high)
yep ...there will be (is) some hell comin out of that van
Right, so you want some more pics..
Lets get the source end of things going.
I loose the gauge little later... I didn't want clutter anywhere.. Clean and streamline...
Ready for another batch of pics? sure you are!! OK so this is of the door builds housing 6 sets of Ascendant Audio Havoc Components running fully active.
