MIKE W
just ordered 18btl dual1 fully loaded which amps do i need to run 0.5o
.5 ohms is a bad idea.. just get a kicker kx.2500.1.. will be safer in the long run.. spend a little extra now instead of buying amps now and running them at .5 ohms and frying them.. then you'll really be screwed :fing34:
ORRRRRR.
e-mail Fi.. if it's not too late.. and request your order to be changed to the Dual 2 option.. then you can find a cheaper amp that is rated it 1ohm etc etc
Edited by mbarber25
we are answering your questions in one topic, why make another one right after it. just ask all the questions in the same topic and someone will get to you eventually.
If you are going to buy another sub you could get the saz-4500, and run it at 2 ohms until you get the second sub. Then run both of the subs off the 1 amp at 1 ohm.
Edited by mdizzle5472
Tip: click inside this box to load the editorIf you are going to buy another sub you could get the saz-4500, and run it at 2 ohms until you get the second sub. Then run both of the subs off the 1 amp at 1 ohm.
yea. what he said
or do the same with a saz-3500 since the 4500 might be out of your budget
Edited by mbarber25
that and it doesn't come out for months. He Just ordered his sub I think he wants to play with it.
