Mark LaFountain
Sundown SAZ-4500D
Finally up on the shop. PRE-ORDERS only right now.
Sundown SAZ-4500D
Regular price will be $1549 MAP / $2149 MSRP once they are released and on the market... you can buy at a HUGE savings on the pre-sale.
The picture is in a generic casing. We are ironing out the details of tooling a case that looks as close as possible to our SAZ casing before release - it will be a wider case but will look as similar as possible to the SAZ amps. Pictures are forth coming as the details are finalized.
Rated Power :
4500 x 1 @ 1 ohm
2000 x 1 @ 2 ohms
900 x 1 @ 4 ohms
TEST RESULTS SO FAR :
3100 Watts @ 1 ohm nominal rising to 2.67 ohms on 14.4v dropping to 13.6 volts
4650 Wats @ 0.25 ohm nominal rising to 0.71 ohms on 14.4v dropping to 11.6 volts
You will get more with a beefier electrical setup
5290 Watts @ 1 ohm nominal rising to 2.12 ohms on 17.9 volts (did not measure drop)
6930 Watts @ 0.5 ohm nominal rising to 1.31 ohms on 17.9 volts (did not measure drop)
