lilwhteranger
plexi glass enclosures
ive seen sum all plexi glass boxes and there pretty sick. how do u make one? wat would u use to seal it together and how would it sound?
You would use plexi-glass to make it. You would use an acrylic adhesive to put it together and seal it and it would be $$!
Make sure you use at least 3/4" to 1" material and let your adhesive set up. In the past I made large acrylic aquariums, planning and prep is everything.
Edited by nmssd12
Get ready to be sticker shocked as it is really expensive to do.
besides price. im worried on how it would sound. i hear its alot different then using wood.
Sound can be the same when built right, but instead of $20 worth of wood you might have $1000 worth of glass
I Did Mine For About 50-70 For A Little Sheet Of 3/4 In. Plexiglass
I was comparing 4x8' sheets of MDF with 1" Plexi. By the time you add glue and other stuff it will be closer to $1k than $100
For sure!!
Plexi and Lexan enclosures are not as acoustically dead as a good solid MDF
enclosure...I have built several but price VS performance I would rather spend
money on other things
if not assembled right the Lexan/Plexi enclosures with large pannels sound absolutley AWFULL
