Generation X
if thats 1200 per sub i would go with the bl, personally. but as you said "for the money" the AQ subs are obviously cheaper. ive heard both, and both get plenty loud and you wouldnt be disappointed with either.
if thats 1200 TOTAL i would look into different subs....nothing wrong with underpowering, but if thats all the power you have you should consider a different choice of woofer(s).
Does the subs sensitivty makes any difference in output.
Example Fi Bl18 spl/94.1
AQ hdc3 18 spl/89.8
btw the amp underated 1200-1575ms
Edited by BassMan808
