wrldzmyn
Enclosure for FI Q 12 done but with ?????'s
ok built my enclosure,
40w x 15d x 10h external dimensions w/ 3/4 mdf
port is
10h x 4w x 21l
im getting different answers on cu ft, what did i end up with when all is said and done ?
ive been out of this for so long i feel like an idiot with all the questions, but you guys are a really great help. THANK YOU
Edited by wrldzmyn
I dont see how your getting 10 for the port height, thats not possible.
However if the inner dimension is 8.5h of the port.
Then it looks like your at 1.73cuft@41Hz
(not good for a daily setup)
^thats with speaker and port displacement included.
I came up with 1.983 cubic feet after speaker and port displacement.
Edited by OldSkool_08
I get 2.5 Cubic Feet tuned to 39Hz
What changes to the port need to be made to make this enclosure go from 39 down to 32Hz. I am about to build a box.
40 sq in of port area? Isn't that a bit much for a single 12? Should be more like 24-32 sq in. I'd try decreasing your port area then your port length will be much shorter for a 32hz tune, more like 24in.
