blkmrideon22s
2 SAE-1200D
i have a d1 nightshade 15 and i was wonder if i could use one sae-1200d to each coil? if so would i wire each coil at 1 ohm?
You can't "wire" each coil. It's one ohm regardless.
In the proper box, the NS should handle those amps just fine.
Easier to just say NO . You can but would probably damage the sub . The sae1200d is not strappable therfore , the chance of getting the gains and settinga exactly the same on both amps it going to be near impossible .
They can be strapped with a Max-Link. I think you'd be better off running a single saz-1500d @ 0.5ohm.
Agreed
