mbarber25
Box Questions
Wudup guys I need some help/advice once again about my box that I just picked up today..I made sure to include pictures so it'd be easier....well just look at it...a 15" BTL is going into it and i know it has the size. I punched the dimensions of the box into a box calculator and it's around 4cuft. But look at the ports..they look too small. Are they? I've never seen ports on a box for a BTL that look so small..look in the third picture. Also you can see that it's not an L shaped port...it just kind of ends..it's just straight as you can see in the third pic... Anyways it's supposed to be tuned to around 32hz but i can't figure out how i can make sure it is...any help? I'm just confused and scared that I just paid $300 for a box that's not right. Please help me lol. :Doh: I just need to know if someone know's how to figure out what it's tuned to and that stuff. Here are the rough dimensions of the box if anyone can figure it out. :wacky:
38.5" Wide
17.5" Deep
15" Tall
Ports are around .75" Wide
1" MDF
Close up of one port.
Inside pic...one of the ports.
Your lacking port area badly..
my stomach just dropped fml.
Sorry man :shrug:.
But from the looks of it(id guess the port length is about 9" on each side, based on the 3rd pic)
If thats the case you are tuned to 32Hz. But are lacking port area badly.
is it really that bad? bad as in i should get my fuckin money back bad? do u have a way of figuring out what it's tuned to?
i'm going to go mesure the length of that thing....but if it's at 32hz i'll feel good about my purchase..that's what i wanted it at anyways..thanks for your help...brb with the measurement
Im getting 29Hz. And youve only got 39sq" of port area.
You most likely will have some port noise.
wonderful. is 29hz alright do u think? kind of low i think.....i'm not competing...this is going to be a daily setup...thanks again
Ye it's fine. It will be good if you listen to mostly rap
lol that's all i listen to actually 98% of the time...so i can be happy with 29hz...it'll sound good still?
