felickz
Dual ported enclosure setup
I have read alot on building ported boxes in the past couple of days but here is what i was planning on....
Putting two kicker 12" L7's in a ported box.
Here is my ?
When porting the box is it more efficent to put one port out the middle where both chambers connect to, or to port each individual enclosure on either side/ or in the middle just separated!?
If using just one port is there a need to separated the two chambers before the port??
THanks!@
I put my port in the middle because i needed the extra bracing.
Some use a common chamber, some use dual.
Common uses less wood and makes it that much lighter.
i like the middle port due to what supa jsut said..it's like having a built in brace...
common chambers are easire to build and less expensive, but if the port is long, doing a center port can be difficult. individual chambers aren't as easy but offer a few advantages...if one sub blows, u can still play the other, the center style port will actually be two ports and if they are long they just become typical "L" style (my preferance) and they add a lil more bracing..
as to efficiency, i'm not to for sure which is a more effiecent design...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
this is a great question, most SPL installs I have see usually run a common chamber where as most SQ installs I have seen run individual chambers
SO, a box setup like this with no divider would be my spl dream???
And does make so much more sense with bracing and such!
@ = @ir
- = wood
speaker = kicker
------speaker-------- @@ ---------speaker-------
if u port like that, which is possible, but the back legs will only be have as wide as the overall port. u'll be dividing the port two ways, so u divide that part in half (only the width)...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
So more like..
no..not the length..the width....
like it's 14.5t x 2w x whatever long..when u get to the "T" part..the port on each side will be 14.5t x 1w
does that make sense? lol...if not, i'll try to draw one up...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
So you are saying that if the main port is 2"wide and the back 2 ports going to each chamber are 1" wide, this is ideal??? if no then you lost me hahaa
I can't stop watching Bubb Rubb...it's mesmerizing.
Yes, thats what he means.
thanks you..lol
and he's right..that's what i mean...
and i try not to look at bubb rubb..he's contagious or something...wooo wooooooooooo
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
No matter how many times I see the whistle-tip video...it's funny. I agree with Kent, it's a disease or something.
Stupid news reporters, they always have to pick the dumbest idiot on the planet to interview..........whistle tips???.....there's none of that down here in LA........worthless news system that reports 24hr of bs.........this must be a channel 11 sister station.........same dumbass hyped up nonsense........"Tag Bangers; tonight at 10"..........idiots...........
