ric
T/S Parameters for the 6.5" poly's
anybody know where i can get a copy?
thanks guys...
If your talking about the originals here you go:
Poly 6.5 Specs
Top of Page
T/S Specs
Driver Specs
Znom 4 ohms BL 5.43 n/a Cutout diam. 5 13/16
Re 3.2 ohms Sd 140 cm2 Outer diam. 7.00
Fs 46 Hz Mms 16 g Mounting depth 3 3/16
Vas 20.8 L Xmax 11.5 mm Weight 2.6 pounds
Qms 2.714 Spl 88 dB 1W/1M Voice Coil diam. 1 1/4 inch
Qes .501 Rec. Power 25-100 W Voice coil 4 ohm
Qts .423 Rms 100W Cone Curvilinear Poly
Le .05 mH Price $35.00 Warrranty 3 years
original? hmmm... this is the polycone and not the kevlar cone right? does the kevlar have differences?
The new carbons are different, I forget what the differences are tho.... If someone Has the ts for the carbons, I'd like to see them.
Edited by lithium
me too, for comparison... i just hope somebody could help out...
