shizzzon
Brushing resin on inside of box
So i got bored today and wanted to squash this. I took 2"x10" pieces of MDF, one with nothing(control), one with a thin layer of resin on one side, one with a thin layer on one side and one covered in resin. I let it cure for 4hours outside, in the sun at aprox 78-80degrees. Could have been longer but it was enough. The control took 12lbs of pressure to break. one with resin on top took 15lbs, with resin on bottom however took 12lbs, and covered completely took almost 18lbs. Nuff Said
I cant believe you guys pissed on this dudes test???? Im not going to argue anymore, because just as you guys have told me how hard headed i am in listening , you are no better. You guys chopped up his test like crazy. Like i said before, NONE of use are going to push the MDF to the point of finding its newly found brittleness that the resin adds. BUT, we will be able to use the small amount of hardness it offers buy stopping a few MM of flex. And thats just an added plus to the smoothness the TL loves from the stuff.
