high_score_1
mids/highs to match?
im planing on putting 2 icon 15's in the back of my explorer...
what kinda mids and highs would i need to keep up with the bass?
i've only done like small setups before so im not sure what kinda speakers i need,
i dont have much of a price range, just wanna make sure my money is spent well
and not something crappy.
i wanna run them to a sundown 100.4.
and suggestions?
(btw all the door speakers are 6x8's)
thank you for the help
If you want to stay with a 6x8 I like the Kicker KS series Focal 570CA1. The Kickers run 120 retail and the Focal 300 retail
Check out the Mach 5 MLI6.5's. You can always make an adapter for them to fit your doors.
Do you have a budget? Are you considering running active? Can you survive without the rear fill?
Don't run 6x8s. With a wooden baffle those speaker holes can be easily adapted to fit 6.5" mids, and have enough clearance for most good speakers.
i kinda have a budjet, i'd like to stay cheap and save as much as i can.
im not competing or anything just a daily driver so it doesn't have to be the best
i just dont wanna wasit my money on unreliable stuff.
i've never had a four door.
so not sure on the rear fill thing.
i want to put speakers in all 4 doors, possibly run 2 6.5s up front (each door)
and run 1 (each door) in the back? i'd have to get a second amp though.
what do you listen to?
It all depends on your definition of keep up.
If you want to stay cheap, you will have to forego the rears but they don't do anything positive anyways. What level are your install skills?
How much processing will you have
get another 100.4 and run a three way front active.
then you could mix and match diy drivers for cheap.
and keep up sound wise.
my three way front gets loud because all drivers play only in there sweet spots.
and show no signs of stress because of it.
what about running rockford fosgate power 6.5 comps and run 2 in each front door, (fiberglass them in)
then get a second saz 125.2 and run two more 6.5 comps in the rear doors?
i'd have to get different rear door speakers though, cause the power handling right?
if not would two more rockford power 6.5 comps work?
the processing is something else i was gonna ask about,
would i need a rockford 360 or something like that?
Edited by High_score_1
With 2 15's Icon in the back, you will never hear the rear speakers, unless you open only the rear doors : too much bass!!!
Your passengers on the back seats won't hear them, with this bass hitting them!
Put more money on your front doors speakers, a good amp and deadening products : and it will be "GOOD TO GO"!!!
so.
say screw back doors,
and run two 6.5 comps in the front?
now anyone have experience with rockford power 6.5 comps?
i know rockfords reliable but i wanna know some feed back from other people.
And still you haven't shared your budget...
But yes, I would suggest ditching the rear speakers and spend that money on going active or at least a better set of components for the front.
sorry bro thats my bad,
but for the speakers, priced by pair, no more then 200.00
and i'd rather stay under 150.
