fritosaregood
Axis 15 Kerf Port Box
I decided to build a kind of fart box for a local comp to get higher scores. and while i was designing it i thought i could make a second port for daily use and shove it through my backseat. I wanted to get a box for two 15s in the car but the most space i could get with the design i had in mind was 2.375 cubes per sub and i want more. so ill be using this box for this month then work out a new design based on this new box to get 2 15s in my trunk. this box will be a little over 4 cubes, with an external flared port, and lots of threaded rod and carriage bolts.
i spent most of the day getting this far
Looks different. Can't wait to see the finished product.
thats some skilled carpentry man!!
thanks everyone.
i had to use a hand saw(whats that??) to finished the kerf cut cuz my tables saw wouldnt cut high enough
i should have more done tonight, then more pics.
Anxious to see this done :)
seriously, this is the most unique flared port box i have ever seen
Good looking flares !
Now that's nifty :D
ive thought about doing something similar. good to see someone else pull it off since im too lazy to try.
nice work sir!
thanks all of yall. I wanted one big port and i wanted it flared. the biggest aero port was 6 inches. i saw how to make kerfs, tried it, and it was pretty easy. So i decided one a big square flared port. It came out better than i thought
I have more done including an inside flared part, the pics will be up soon.
thats impressive. wish i had the time and skill to pull something like that off
that is so SICK man post so vids asap
i might not do a vid of this port because its tuned at 49hz for comps. but after i get the box in the car i can measure for my daily port. after that ones built ill make some vids
I had a few finals today so i didnt get much done.
I got the top baffle on. i just using a single baffle because ill have threaded rod for bracing. I also sealed the edged with more fiberglass and made more 45's from resin. I didnt get to many pics of it since fiberglassin gets pretty messy.
I also got some toys today..sorta
^^ wat i get for bein on ebay at 3am I found some 3in air sander disk things 25 for $20 nice deal, some rubber grommets. 150 with different sized i think it was $7. and 2 fuse blocks.. i ran into a problem with my alt to batt wire got laid on my header and came about a millimeter from melting throught the wire loom and wire jacket. so now i wanna fuse both ends just to be safe. Ill get a pic of wat the wire looks like.
I got a little more done
I cut the whole for the sub, put it some t-nuts, and put in the threaded rod. now i just have to find my small bolts to make the terminals. I used some carriage bolt with the theaded rod mainly to keep the bottom of the box close to flat so it lays down better
those expensive little things. almost $4 each
i had to screw that nut over 3 feet. then i had to do it again for the other one.
Edited by fritosaregood
looks fudgeing sic internal sshot
