lamchop_8
Fi.BTL 18 Or RD Audio Heavyweight 18?
Looking at the t/s parameters, yes.
And it will also be alot better for a daily application.
Yes thats what I plan on using the RD for daily and how much louder will it be by db?
You ask in the Fi forum and expect any answers other than BTL?
Couldnt say, but it look's like the RD is more for a spl/burp scenario.
BTL if you want or ever need customer service, BTL if you want the product to hold value, BTL if you want top quality engineering.
Based on T/S parameters, the BTL. But that isn't the right way to judge a woofer.
Edit: You have a BTL in your signature why are you asking about the RD?
Whatever sub I get is going to be tied to a SAZ-3500D getting about 3800 rms so will the Rd sub handle the power better than the btl since its rated at 4000 rms and the btl is rated at 2000 rms?
Mhm, thats all i can go by seeing as I have no personal experience with both woofer's.
IF you know what your'e doing, and if it has a proper enclosure then it will handle that fine.
Me as well Rob, just saying.
The enclosure will be 12.6 cuft after all displacements walled tuned to 34hz. so being said with that enclosure will the btl's be able to take 3800 rms a piece daily all day everyday without blowing or should I make the enclosure smaller by a lil? If so how much?
Ye i wasn't bein an ass :)
I made sure to mention on my first post that i was basing it on t/s parameters.
Like i said, if you know what your doing it should be fine :)
6.3cubes a peice should be good.
Okay thanks becuase the RD Heavy weight is 750 and I want to get the loudest and best made sub I can for 750-800 max. Is 3 Kinetik Hc2400 batts and is one or two 200 or 300amp alternators enough power for me to play my setup all day everyday?
1 300amp and those 3 kinetiks should be good, but if you have money to spend then you could go for a dual 300amp alt setup
Always good for future upgrades.
Okay last thing keep it real with me would you pick 2 fully loaded btls over the 2 rd audio heavyweights I listed for the loudest and highes db you can reach?
And do you think I can fit 2 300amp alternators in a pontiac grand am gt?
Edited by Randy.D
You have been her for quite a while, and you know how things work around here. Yet you ask a question like this?
You have me confused here, do you want strictly spl or a good daily driver that still can put up some pretty good numbers?
Most people dont give me staright answer they beat around the bush. I mean I feel what you are saying but you know I just want to get the best info I can. Could you please tell me what you would pick?
I Want a good daily driver not stricty spl.
loudest and highest db you can reach?
You can pick high numbers OR you can pick loudness.
Now when you say high numbers you mean stricty spl right?
