Doctor Q
Contemplating on Upgrade Ideas.
So right now i have a 15" Q in a 4 cu ft ported box... sometime late this year or early next year i was thinking of upgrading to either another Q so (2) 15" Fi Q's or (1) 18" Xcon?
What do you guys think about this?
I am willing to pretty much give up my whole trunk so basically i want some SQ but more focused on getting loud... i like the lows ALOT... i want enough SQ so i can listen to some real rap and underground stuff that has quicker fast hits so i want to be able to listen to stuff like immortal technique and be able for it to sound good... but want to listen to jeezy and be loud as chit... so basically compromise between the two but more focused toward being loud.
I have a few people intrested in my current setup so i can sell my amp (sundown 1200D) my sub (15 Q) and my custom made box... so i can sell all that and put some more money on top of that for the new system... for the amp depending on what the sub(s) i get can handle probably a sundown 1500D or maybe 2000D if i need it... then for the sub ill spend no more than $400-ish. Then ill get a custom ported box.
First i just want ideas for what subs i should get... 2 15's vs 1 18.. whats the pros and cons for each?
thanx,
alex
Let's not use the term "sq" for this. What I'm gathering is that you want a sub that plays rap loud, but doesn't sound like a tin can? I'd say get a BL in that case. Those will get "low" enough for the type of music that you listen to.
Also, how big is your trunk??
um im not exactly sure. i can get those measurements tomrw. why would you reccomend the BL over something like the Xcon. Doesnt the Xcon get lower, louder, and sound better?
