Michael914
FI BL amp Suggestion
I Have 2 12 Inch Fi BL's and i dont know what amp i should go with i was leaning towards a sundown audio 2000D but also was looking at soundstream PCX 2000D .. any suggestions on what i should do ?
i wanna wire them down to a 1 ohm load .. as far as my electrical gos i have a inetic battery under my hood. i wanna run a full 2000 watts ( a 1000 for each sub)
Just because you want to wire them to 1 ohm doesn't mean you can. What coils did you buy?
You'll Wind Up With Around 1250 RMS Per Driver With A 2kd On 2 2 Ohm Bl's. I Ran Mine At 1800, But That Would Be Fine, If You Have Dual 1's, You're SOL.
Edited by BigCProductions99
2 Dual 1 ohm coils can be wired to 1 ohm.
im deffinitly leanin towards the sundown ( how do you hook up the fuse to it tho i dont understand how )
do you guys think this system will be enough to take my breath away
You use an in-line fuse holder for it, and a 200 amp fuse.
if you can wire them to one ohm, you could get the aq2200d. It's really cheap($389).
Shut up.
...Did I Seriously Get My Ohmages Backwards? Lol.
But Yeah, I Agree With Duran On The AQ2200D. Lmao.
Shut up.
Whats wrong with it?
What do yall think about the Hifonics BXI 2010D amp for those subs?And what is better, wiring each 2 ohm BL down to 1 ohm and giving it its own input at the amp or taking two 1 ohm BLs and wiring them up in series for 2 ohms and then wiring them in parallel at the amp back down to 1 ohm?
