Bobaflob
Dropped phone in the toilet......
open up the back, take off the plastic shell, spray contact cleaner in it and leave out in the sun. Don't get onto the screen, lense or microphone areas
hope the toilet was clean lol
Already started the process, thanks for the advice(Toilet was clean)
Shell is held on with an extremely small torx screw, dont have one that small at home.
Wrap it in a sock over night and put it in a dry place.
Should work :)
I read somewhere that you can put it in rice to absorb the moisture.
if you let it dry out it will work again just don't try to turn it on till it dry. I washed mine in my pants one day..... after it worked better
That rice trick works?
it did for me...i just let it sit a long time to be sure it was dry.
bought a bag of rice took the battery out put both in the bag of rice and let it sit for a couple days.
Set in a bowl of rice over night and now the phone works. Right after this I preceded to drop my netbook 4 and half feet, but its in perfect working order.
Rice can't fix the laptop if it falls from too high :P
I think you need to start attaching bungy cords to everything and your body so things do fall all over the place lol
sounds like a good idea
