87regal
maw-15 specs
found them:
Power Handling: 500 Watts
SPL (2.83v/1m): 90.2 db
Impedence: 4 + 4 Ohm
T/S parameters (with coils wired in series):
Fs = 26 Hz
Re = 8 Ohms
Qt = 0.32
Qes = 0.35
Qms = 3.35
Mms = 232.8 grams
Rms = 11.42 kg/s
Cms = 0.000159 m/N
Vas = 129 liters
Sd= 756.3 cm2
Xmax = 13 mm
Diameter = 31.1 cm
Dimensions
Outside Diameter: 39.4cm (15 1/2")
Mounting Diameter: 35.6cm (14")
Depth: 16.8cm (6 5/8")
I believe we still have one or two left of B-stock. Their boxes are so messed up they would probably have to be pick up only or I need to rig up a box.
