ShaneSauce
Needing opinions on a new setup
So I have had my SSD hooked up on my zx750 now for about 3 months and I love it to death it sounds amazing and all the kids up at the high school chit bricks when they hear it.
I'm guessing I'm hitting in the low 30's on TL.
AND I FINALLY FIXED THE RATTLING!!!
But I want a bit more, it would cost around $1000 dollars if I sell my SSD&amp for $500.
I'm thinking cut out the upper trunk railings so I can fit a 5cuft box in my trunk instead of a 3.5cuft box
(1) Fi BTL 15 fully loaded
(1) 2k-2500rms amp (possibly sundown2000 when it comes out)
1 run of 0 gauge, 8 gauge speaker wire
And obviously some batteries, not too sure on which ones and how many I'm going to need(suggestions?)
Go out there and re-measure.
Give me the maximum height width and depth.
If width changes with height, etc.... let me know everything as detailed as possible.
I've had people tell me they only have so much space when they really have more.
Let me know what u come up with...
Also, what year make and model car is it
My current box is 13.5" tall, 26" deep, 28" wide.
Its 3.5cuft @33hz with about 50 square inches of port.
Sub is firing up(only way I could do it)port firing back.
The only way I could get a bigger box is by cutting out the trunk railings that hold the trunk up when you open it.
I could make the box 17" tall and that would put me at about 4.5cuft
And its a '97 Toyota Tercel
So, does your box go from wheel well to wheel well or is it the whole width of the trunk?
From well to well, and its about 28" wide
28" from the back to the front of the trunk where it shuts, I gave 2 inches for breathing room.
The thing is if I cut those railings out I can make the box 17" tall meaning I can mount it facing forward instead of up also.
But I have the enclosure under control I just really need electrical advice and some 2krms amp suggestions for around $500.
