iputon326
battery terminals
where can i find battery terminals with two 0 guage inputs.
the only ones i can find have one 0 guage and one 4 guage.
KonFused
I've heard of people having trouble with them though....it does fit your need though.
KonFused
what problems did they have?
i own Konfused so i can tell you.
Konfused terminals use a furrow to wrap the wire around then screw it back into the terminal...
The problem i had is when you wrap wire around the furrow then go to tighten it back into the terminal.. it's ridiculous.
I actually stripped an entire battery terminal just from trying to hand tighten it back in, that's why.
Good thing i ordered extra terminals though. I tossed it to the side and just got another one and it worked finally.
You shouldnt have any problems with the terminal actually fitting on the battery post.
I know it doesnt go all the way down on the post but once it's on there.. it's tight just like any other terminal is.
there other terminals in the link i showed would be the ones i'd suggest.
They are only $12 and are nothing out of the ordinary.
cheap and easy/
