csills89
question (newbie kinda)
* 2 Channel Mosfet Bridgeable Amplifier with built in Crossover
* Maximum power output @ 2 Ohm 800W x 2CH = 1600W
* LPF (low pass filter) variable & HPF (high pass filter) variable
* High and low adjustable level input
* Mosfet DC-DC switching power supply & LED indicated power status
* Built-in protection against short circuit and high temp
* Tri-mode speaker connection ready & Bass boost (0db-18db)
* Auto power on/off by remote (+12V)
* Dimension (W x H x D) mm: 287 x 64 x 429
* Chrome Heatsink
* All measurements done at: 14.4V DC, 1KHz input signal
i got that from the actuall website @ http://www.dieselaudio.com/element_amplifiers.html
i believe that website i gave you up there is wrong mabye
so im not pushing my subs at the right rating? well i cant really do anything about that now until i get some more money for a amp in the long run, so will it still be bangin
* Chrome Heatsink
I don't know what "bangin" means. Give me a better definition of what you want.
Still hard to answer your question as it is completely subjective. Meaning: What I consider "beating" and you probably do are two completely different things. You will have bass with that setup. Will it make your vision blurry? Probably not.
That amp will work. If you get that amp, get two D2 subs and wire them at a 2ohm load. Assuming it does rated power, it will be a perfect match for 2 Fi SSD's.
I think you should really put off buying ANYTHING and go read up A LOT. No offense :) We all were noobs at one time lol!
