sundownz
Sundown SA-12 D4 Pre-Order
Pre-Order open as of now - be sure to get these while you can as I think the first run will go quickly.
ETA is mid to late June for arrival of these woofers. As always, with a pre-order the ETA is subject to change based on shipping delays, etc, etc. PLEASE do not pre-order unless you are okay with any delays that may occur.
Regular MSRP will be $239 dollars - right at our low 200s target :)
Shipped prices in Continental 48 states -- contact me for AK and HI -- USA ONLY pre-order!
Paypal me at [email protected] to pre-order.
$175 shipped for ONE
$330 shipped for TWO
$620 shipped for FOUR
Ask about more than that.
Two of them in my Jeep has done up to 149.7 dB in a box that is too big with too much port area, so they have great SPL potential.
Not only that - but they are GREAT sounding drivers with terrific low-end extension. They feature an aluminum shorting ring and a high linear x-max of 19mm one-way.
RE: 7.09 ohms (D4 in series)
Fs: 28.4 Hz
Qes: 0.511
Qms: 5.75
Qts: 0.469
Vas: 40.3 L
BL: 25.04 NA
Le: 7.7 mH
Mms: 252 g
BL^2 / RE: 88
600 watts RMS
Depth = 6.5"
Cut-Out = 10 15/16"
Enclosure Suggestions:
1.75 ft^3 ported tuned to 30 Hz -- F3 of 26 Hz
* Tune higher for more SPL oriented setup
* Enclosure can be as big as 2.25 ft^3 if you stick with the 600 RMS rating
1.00 ft^3 sealed -- F3 of 44 Hz
* For SQ and space limited applications
I wish I had a need!
Should be a great seller after seeing the prototype numbers.
wish i had a need for it. been telling one of my friends about it. so i'll try and get him to pre-order one.
how much power were you runnin in that jeep setup?
A bunch - IIRC I hit em' with about 2500 each on a burp.
In a proper enclosure they would do much better -- my box has too much port area and is too big for a pair of 12s :)
looks nice just what ive been hunting.. time to have a talk with the wife
Do it! :)
A bit more in depth...
These drivers feature the same cooling arrangement I developed for my Monster SPL woofer therefore thermal power compression is very low on these drivers - the 600 watt rating is purely mechanical as these will handle substantially more thermally.
The coil is a 2.5" diameter / 45mm WW copper coil on an aluminum former.
We are using flat, tied down tinsel leads to avoid the possibility of slapping the cone.
Any more questions - let me know :)
Anybody have any questions about these ? :)
Would 4 cubes be good for two on a SAZ-1500D or would I need to go smaller with the box?
damm 4 sound nice with a 3500??????? hmmmmm
With anything over rated power stick to the suggest box size or smaller.
These are in transit to me so the ETA for late June seems to be on track.
would my saz1500d be to much for one of these?
It would be at 2 ohms so it would be just a little bit too much - you could *easily* run two with a 1500D.
yea i fig. that.... i would love to have 2 in my truck but i think i would have to lose my back seat and i cant do that... which i think i can squeeze maybe 2 cubes under it...hummm
I got word they should hit Charlotte customs around the 16th of this month :) Get your orders in now if you want some!
