gmc123
how big of a port in inches and what hz should i use?
im building a wall for 4 xcon 18s ill have about 27 cu ft. and i want to do 2 ports on each side any ideas
You could make each port 125 sq. inches and 19" long. That'll give you about 23 cubes after displacement tuned to 32 hz. I think ideally you'd want more room, but that may work.
i know im going to try to get as much box as i can but would i be able to just make the ports square or would i have to turn it anywhere?
in building a wall in a blazer for 4 xcon 18s and im putting 2 ports. i have about 32 cu ft. im going to run 2 soundstream 10,000s rms 7,500 and can i just build the ports square or so i need to turn it?
as i say to others, put a bit more effort into making an interchangable port system and then fine tuning playing with lengths to get the best result.
well the only reason i have to do 2 ports is because i dont have enough room for 1 big port but i can put 2 because my box will be bigger at the top then on the bottom because my wheel wells
That obviously depends on the depth of your box.
:WELCOME:
Why did you create basically the same topic in the newbie sign in forum after this one?
Merged.
no its in a regular 4 door blazer. the box can be 34 in deep
