rk772
HiXmCoil
What is the Xmax with this option? I only see the 28mm on their website and I assume this is without this option.
28mm is with. I think I remember Scott saying 16mm without.
If it is for daily, I would definitely get it.
I actually just found it on their website:
Need incredible Xmax to feed your 160dB at 20Hz obsession? Add our extended length coils (28mm of Xmax). With over dozens of different option combinations to choose from, we can build the exact sub you need to fuel your SPL fire.
Info for all the options is in the tech section too.
Thanks,
Scott
