bjfish11
Box Build for 350zspl
This one is 3 cubes @ 35 hz for a trio of DD 1508's I believe. Used a pair of 4" precision ports and had to put an elbow on each. Box will be left bare and have all edges rounded over.
When you measure the distance of a aero port that is curved, do you take the inner side, the outer side, or an imaginary line in the middle?
Down the center. In this case, the center length of the elbows was 10" IIRC.
Very nice, I loved my 1508's. can you get a pic of the elbows?
If I remember Ill get some pics next time I use them. But, they are just standard 4" 90* PVC elbows.
Amazing work!
I love the look of the unfinished box. Alot of sanding to get it to look like that?
Amazing work!
actually trupan has a better look to it over mdf when both are non-finished
so more the wood itself over sanding leaves that type of finish
but with exterior edges routed , woofers counter sunk, and trupan as the material , it comes out looking so nice no need to cover IMO
Amazing work!
Nope, not much sanding at all actually.
go to home depot
pvc plumbing isle
4" 90 degree elbow
you can source them there
Edited by 350zspl
When you make your initial cuts out of the sheet, do you use a table saw or a circular saw?
Table saw all the way. Much better than a circ saw.
Where do you get Trupan at? Is it available at a local lumberyard, Lowes, Home Depot or Menards?
Edited by OldSkool_08
not sure exactely were he is buying that wood at, but hes been using it for years
Edited by 350zspl
saw it at home depot for $49 a sheet i believe.
let me know when you are ready to drop a saz 3k in your ram
i got a mint one for the low low $
judging by your username, is that going in a 350z?!?! i didnt know the trunks were that big. very nice looking box btw.
thanks
max exterior dimensions in a 350z
32x15x19
