3stagevtec
DC Audio Level 4 15"s
Will be using them for SPL competitions in IASCA.. will post my scores here..
Power - 2 Sundown SAZ1500Ds
Batteries - 1 Powermaster D2400 up front and a D3100 at back
Powermaster 140A alternator
Headunit - Pioneer 6000UB
Preamp - Soundstream 6XO
Audiocontrol 6XS Crossover
some hott dust caps!
stitched tinsel leads, nice!
the score to beat is 150.5dBs on the termlab (151.6dB AC) i made using a pair of Audiopipe TXX 15"s
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
i came 3rd in my 1st competition with them yesterday with a score of 150.1dBs.. the box used was poorly tuned and installed last minute for the competition.. no testing was ever done..
Advance 2
1st Ronald Suhkbir 154.8
2nd Mohan Ramlochan 152.1
3rd Rene Roberts 150.1
4th Shameer Baksh 150
5th Adrian Boodoo 147.8
the 1st place score was made by a walled off Mazda 323 hatch-back, running a 7000W Cactus Sounds amp and 2 15" Cactus sounds subs..
2nd place was made by 2 95series 15" Digital Designs subs powered by a pair of 5000W Atomic amps!
my personal goal is to beat those DDs :D
Those things are so sexy. I can't to get mine. I am only getting one with 1000 watts to it, but I am sure I will be impressed.
thoe boxes were made for my previous Audiopipe subs, so they are not really a match for the DCs..
they are 5 cubic feet each currently tuned around 46Hz! 3 - 5 layers of fiberglass & resin on the inside and a coat of resin on the outside to prevent the mdf from absorbing water.. double 3/4" mdf baffle.
i have to bring that tuning down to about 40Hz so it would better work in my vehicle.. when i lower the tuning, then i'll make some vids..
wow rene ... i have high expectations , cus i know you know your stuff... will you be ready for the show in may?
i lowered the tuning freq to about 40Hz (net volume dropped to 4.1cu.ft) and just hit a 151.6 on the Audio Control meter this evening..
i believe another 0.5dB is possible with these boxes..
question, what's the best score you guys have seen made with around ~3200Wrms.. my personal goal is 152dB but i not sure if that is high or low for my power..
I did 152.2 with 2.2k and four 12inch jl aduio w3before
And 155 with 4.4 k with four of these 15 lv4.
So i'd say your score is every good
boxes are 4.1cu.ft each tuned around 35Hz..
power comes from a pair of Sundown SAZ1500D amps at 0.5ohms each..
My front stage is a pretty quiet pair of CDT components, they get drowned out quite easily...
